Will these components work smoothly together?
jpk2128
So I haven't built a PC in years and I've recently been asked to build one for some serious numerical simulations. I just want to double check if everything I've selected will work nicely together. My biggest worry is the power supply (i.e. is it big enough?, enough outputs?, etc). Any help will be greatly appreciated, thanks guys!
2 Intel Xeon E5645 Westmere-EP 2.4CHz http://www.newegg.com/Product/Product.aspx?Item=N82E16819117256
ASUS Z8NA-D6C Dual LGA 1366 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131378
2 Intel BXSTS100A Active heat sink with fixed fan http://www.newegg.com/Product/Product.aspx?Item=35-203-002&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
GIGABYTE GV-N84STC-512I Rev2.0 GeForce 8400 GS Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814125359
Kingston 12GB (3 x 4GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1333 Memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820139268
COOLER MASTER Elite 460 RS-460-PSAR-J3 460W ATX12V V2.31 Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817171046
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
LG CD/DVD Burner SATA http://www.newegg.com/Product/Product.aspx?Item=N82E16827136238
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
Sorry for having to click through all the links.
