Will these components work together? new to building PC's
Dogs10188
14
R9 270X graphics card
Asus 24xATA Internal OEM Optical Drive DRW-24B1ST
WD Blue 1 TB Hard Drive3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX
AMD FX-8320
ASUS M5A97 R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard,
XFX TS Series 750W 80 PLUS GOLD Certified
CPU cooler:Cooler Master Hyper 212 EVO.
I have switched the asus graphics to the R9 270X graphics card and XFX TS Series PSU and the AMD FX-8350 to the AMD FX 8320. Are these parts still compatible?
OLD question do not answer
Your post would be easier to read if each part was on a new line.
You have chosen a low end graphics card. It is fine if you want medium settings at 1920x1080.
If you want high settings, consider the R9 270X.
If you want ultra settings, consider the R9 280X.
The processor you have chosen is very power hungry and overpriced for its performance in games.
From AMD, the FX-6300 would be a better choice with lower power consumption and a lower price. You won't notice the difference in games.
If you want a faster CPU than this, look at an Intel Core i5, this will mean a different motherboard.
The FX series CPUs support DDR3-1866 memory while the Intel Core i5 supports DDR3-1600 memory.
You can choose higher speed memory if you like and set...
You can choose higher speed memory if you like and set an XMP profile in the motherboard to use it at the correct speed.
This is overclocking the memory controller in the CPU, but is generally OK up to DDR3-2133.
You can use DDR3-1600, DDR3-1866 or DDR3-2133 with either CPU. The performance difference between these speeds won't be huge.
All these CPUs have dual channel memory controller so choose a kit with two RAM dimms, either 2 x 4GB for a total of 8 GB or 2 x 8GB for a total of 16 GB.
The power supply you have chosen is not the best, tier 3 on the following list:
http://www.tomshardware.com/answers/id-1804779/power-supply-unit-tier-list.html
Choose tier 2 or higher if you can.
Here are some suggestions:
XFX Pro 550
XFX Core 550
XFX TS 550
Antec HCG 620
Rosewill Capstone 550
These are fine for most of the configurations we have discussed.
If using the FX-8350 with the R9 280X, you will have to choose a higher rated model.
EVGA Supernova G2 750
XFX Pro 650
XFX Core 650
XFX TS 650
Rosewill Capstone 650
