Will these components work together?
Peyton_
6
Sorry but have never built a desktop befor and I just need to make sure all these parts will fit.
Gpu-- EVGA 03G-P4-2782-KR GeForce GTX 780 3GB 384-bit GDDR5 PCI Express 3.0 SLI Support Video Card w/ EVGA ACX Cooler
Cpu-- Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73930K
Ram-- CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
Psu-- XFX ProSeries P1-1250-BEFX 1250W ATX12V V2.2 & ESP12V V2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
Cooler-- CORSAIR Hydro Series H100i Water Cooler
Case-- Thermaltake SOPRANO VO900M1N2N Black SECC ATX Mid Tower Computer Case
Ssd-- SAMSUNG 840 Pro Series MZ-7PD256BW 2.5" 256GB SATA III MLC Internal Solid State Drive
Hdd-- Seagate SV35 Series ST1000VX000 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Enterprise Internal Hard Drive
Motherboard-- ASUS P9X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Gaming. I do plan on overclocking the CPU and gpu. I also plan on adding up to 32 gab of ram and adding a second 780 in sli. I know I probably need a bigger case so suggestions are welcome thanks.
Whats your budget?
I mean, sure they will work but its overkill even for gaming.
-You don't need an i7 for gaming, much less socket LGA 2011. Those are meant for workstations. Games don't benefit from i7's hyper-threading. Stick with a socket LGA 1150 i5-4670k.
-PSU is overkill. A quality 850-950w should be enough.
-Thermaltake cases are generally not that great. I would get the Fractal Design Define R4 instead.
