Will These Components Work Together?
GoodBinary
7
[MOTHERBOARD]
ASUS B85M-E/CSM LGA 1150 Intel B85 HDMI SATA 6Gb/s USB 3.0 uATX Intel Motherboard
Model #:B85M-E
[CPU]
Intel Core i5-4430 Haswell 3.0GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I54430
Model #:BX80646I54430
[RAM]
Module Size: 4GB kit (2GBx2)
Package: 240-pin DIMM
Feature: DDR3 PC3-10600
Specs: DDR3 PC3-10600 • CL=9 • Unbuffered • NON-ECC • DDR3-1333 • 1.5V • 256Meg x 64
Model #:CT2KIT25664BA1339
what about with this power suppply, and a NVIDIA GeForce GTX 260 896MB
(i'm going to upgrade my GPU later)
i'm going to upgrade my GPU in less than a year... since mine is meats the requirements for the games i play, and to space out the expense of upgrading.
i could upgrade my PSU then..
i went though this PSU Calculator website, and it said i only need 385w at Maximum... and i made sure to included all the fans i have and everything. (saying that my 460w should be good)
what about the PSU power cord, and it's PINs? has that changed yet, is it still 24 pin connector?
awesome
... i guess i'm going to go ahead and order these components.
my HDDs are 7200rpm and one being 8mb Buffer, the other 16mb buffer... i really don't want to get new HDDs.
As long as you've got data backups, you shouldn't need to.
not sure what you mean?
i have two hard drives.. one smaller 80GB for Windows 7..
and, one larger one for "Media" 750GB
this helps ensure, i never lose anything if my OS gets messed up.
(space is a little tight right now on my windows drive.. but i manage.)
i'm getting a new DVD drive also, cause for some reason mine is shotty.
(it does that thing, where it tries to open but it can't dislodge, and i have to do the paper-clip thing)
i figure i wont have to re-install Windows 7.. that it will just boot up and i might have to install a driver.. but i figure not.
