Will these components work together?
LokiNInja
8
Hello everyone. I am having issues with my current PC and looking to build a new one. Plan on buying everything from newegg. Just need to know if these components will work together. I am a poor college student so I am just going for a mid range build, nothing killer and can't really afford to make mistakes, but I do want it to be semi expandable for future upgrades. Any issues, or suggestions are welcome. Here is the list:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822178291
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157477
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121855
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817438014
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820313434
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113280
Yes they work, but the build is not ideal for the money at all.
Change the motherboard for something cheap ($60).
Change the CPU to an athlon x4 860k.
Use saved money to bump the GPU up to an r9 270.
This will give you a MUCH better experience.
Exactly the type of response I was looking for. Thank you!
