[SOLVED] Will These Componets Work?
Nov 18, 2021
11
I want to build my 1st computer and I need advice as to the components that I have selected are compatible.
  1. Antec NX260 mid-tower case
  2. ASUS TUF Gaming X570-Pro AM4 Zen3 Ryzen 5000 ATX motherboard (PCIe 4.0 2.5 Gb LAN, BIOS
  3. AMD Ryzen 5 3600 6-Core 12- Thread Unlocked Desktop Processor with Wraith Stealth Cooler
  4. upHere 120mm RGB Case Fan (6 Pak)
5.Crucial MX500 1TB NAND SATA 2.5 inch SSD
6.TEAMGROUP T-Force Vulcan Z DD$ 16GB Kit (2x8GB) 3200MHZ
Does the ASUS board have built-in wi-fi or would I need to add a card?
Am I missing anything that will be needed to run this system besides an operating system? (Windows 10/11) 🤔
P.S. I'm trying to put together a sub $800 system
WiFi, and RGB CPU cooler, Memory, and three included case fans. 1TB NVMe SSD rather than 2.5" And a power supply for any mid-range GPU you might be able to get ahold of.
Hard to recommend Ryzen 3000 when Intel's 11th gen are at very low prices.
PCPartPicker Part List
CPU: Intel Core i5-11400 2.6 GHz 6-Core Processor ($199.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler ($44.99 @ Amazon)
Motherboard: ASRock B560M Pro4/ac Micro ATX LGA1200 Motherboard ($117.99 @ Newegg)
Memory: Crucial Ballistix RGB 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($74.98 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State...
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($79.98 @ Amazon)
Case: Antec NX410 ATX Mid Tower Case ($69.98 @ Amazon)
Power Supply: Corsair RM (2019) 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($79.98 @ Amazon)
Total: $667.89
Generated by PCPartPicker 2021-11-18 15:57 EST-0500
I have considered buying a XPS computer from Dell since the computers that I have (5). The one that I looked at with 16GB of ram and 6GB video card would run me about $1300. I have had pretty good luck with their systems but I wonder if their computers can be upgraded easily and other than the video card I have no idea what parts, especially, the motherboard they use. Plus I would lose the fun of building my own!
Try this ...
https://www.newegg.com/p/N82E16813119385
ASUS PRIME B560M-A $109.99
https://www.aaawave.com/intel-core-i5-10400f-6-cores-up-to-4-3-ghz-desktop-processor-bx8070110400f/
Intel Core i5-10400F $149.99
DEEPCOOL GAMMAXX 400 CPU Air Cooler $18.99
https://www.amazon.com/TEAMGROUP-T-Force-Vulcan-3200MHz-Desktop/dp/B07T637L7T/
TEAMGROUP T-Force Vulcan Z DDR4 3200MHz 16GB Kit (2x8GB) CL16 $50.99
Total: $330
https://www.asus.com/Motherboards-Components/Motherboards/PRIME/PRIME-B560M-A/
Review of that cpu with benchmarks.
