Will these DVI cables work with this graphics card?
reconsister2
24
So I recently bought a new graphics card, which is the EVGA GeForce GTX 750Ti. I see that the ports on the graphics card are DisplayPort, HDMI, and DVI-I. I would like to do dual monitors with two dell monitors that have DVI-D ports. Can I just buy these cables to use? Or do I need some sort of DVI-I to DVI-D cable? The cables I linked don't specify the type of DVI connections they're so I don't know if they will work with my setup.
http://www.amazon.com/AmazonBasics-DVI-Cable-Feet-Meters/dp/B00IHMFIBY/ref=sr_1_1?ie=UTF8&qid=1416879727&sr=8-1&keywords=dvi+cable&pebp=1416879744955
http://www.amazon.com/AmazonBasics-HDMI-DVI-Adapter-Cable/dp/B001TH7T2U/ref=sr_1_1?ie=UTF8&qid=1416879737&sr=8-1&keywords=dvi+to+hdmi&pebp=1416879754920
The whole DVI standard is really confusing. The simple answer is "Yes", those are the right cables for your set up.
DVI-I includes the old analogue signal and allows you to use a cheap passive DVI->VGA adapter. You'll be using the digital signal which is also included, so it doesn't matter.
