Will these fans work as pwm fans for my hyper 212evo
G
'Fraid not dude.
I've owned this particular fan before, two of them infact, although I can't remember them coming with 'said adapter.
If the 3-pin is on the fan end then that's the way it is. There won't be any PWM control.
I'm not sure what the point of the adapter is. It will most likely have a 3-pin male connector on one end that you plug the fan into, and turn into 4 by the end of it (The end you plug into the board).
So that extra line on the adapter is probably hollow.
I personally can't see much point to this other than being an inch worth of extension.
'Fraid not dude.
