[SOLVED] Will these fit in the Thermaltake Core V1 SCC Mini ITX Case
Feb 5, 2020
Hi, im building a Mini ITX Gaming Rig. My GPU is a MSI GTX 1080 Gaming Plus X wich dimensions are 277 x 140 x 42 mm (MSI Website), im worried about the Heigth 140mm+Power Cables. I also have an EVGA Supernova G2 1300w PSU wich dimensions are 85 x 150 x 200 mm (EVGA website). Will those components fit in the Thermaltake Core V1 ACC Mini ITX Case?
Neither will fit.
https://www.thermaltakeusa.com/core-v1.html
The case's spec for max cpu cooler height is 140mm - which is most likely rounded up to the closest mm... that's too exact, and thus best to assume the gpu won't fit, since the 2 basically sit parallel with each other in the motherboard
The psu won't fit either, because it's not a standard size ATX model - psu length and the case's psu clearance are both 200mm. Again, that's too exact IMO, and likely won't fit either.
Neither will fit.
Reactions: CasperVanDien
