[SOLVED] Will these parts bottleneck?
Bottleneck calculators are garbage - don't rely on them.
You check the weakest links by playing your games and monitoring the usage in each one. There is no real shortcut to this, because what games you play and what someone else plays may have different needs.
-Usage of each cpu core/thread: all it takes is one to be a cpu limitation. Whole cpu usage is incorrect.
-Ram usage
-Gpu usage
The one that holds back performance the most frequently is the weakest link.
How should I make sure there is little bottlenecking without first purchasing the parts
Asking for advice. Those bottleneck calculators are misleading garbage and anything you have read on it should be forgotten.
Even the best systems can bottleneck in certain circumstances. You really looking for a balanced cpu and gpu combination but also considering monitor resolution and Hz, something those sites don’t do.
I have a 144hz monitor. I don't really know how these things influence it though, pretty new to PC building
