J JustleMyRimmies Commendable Jun 18, 2016 6 0 1,510 Jul 26, 2016 #1 Hey Forum! I'm building a new PC with a Mini ATX motherboard and was wondering if it could fit with a Midtower case? http://pcpartpicker.com/list/WBdHBP
Solution helpstar Jul 27, 2016 just deleted the suggested cpu and added yours without price tag you easily can change the 600W back to the 500W PSU, also changed the SSD to a cheaper one and the 970 I suggested before to a RX480 http://pcpartpicker.com/list/ZFvZf8
helpstar Titan Dec 25, 2012 15,118 1,167 94,840 Jul 26, 2016 #2 do you have a CPU, cpu cooler and the R9 290 already? it will fit in the case you chose, but: the motherboard should be B85m the Ram will be ok with 1600MHz SSD should be installed too changed the PSU to 600W have a look at this suggestion: http://pcpartpicker.com/list/CFfdm8 Upvote 0 Downvote
J JustleMyRimmies Commendable Jun 18, 2016 6 0 1,510 Jul 26, 2016 #3 helpstar : do you have a CPU, cpu cooler and the R9 290 already? it will fit in the case you chose, but: the motherboard should be B85m the Ram will be ok with 1600MHz SSD should be installed too changed the PSU to 600W have a look at this suggestion: http://pcpartpicker.com/list/CFfdm8 I already have the CPU. The CPU is an intel core i3 4170 Upvote 0 Downvote
helpstar Titan Dec 25, 2012 15,118 1,167 94,840 Jul 27, 2016 Solution #4 just deleted the suggested cpu and added yours without price tag you easily can change the 600W back to the 500W PSU, also changed the SSD to a cheaper one and the 970 I suggested before to a RX480 http://pcpartpicker.com/list/ZFvZf8 Upvote 0 Downvote Solution
