[SOLVED] Will these parts work together? Asus wasn't much help
ss_56
291
7
18,795
Hi; i also went to pcpartpicker(asus suggested) site and my motherboard wasn't listed and the suggested memory i saw was not on Asus QVL. Hoping you guys can give me the go ahead on my upgrade.
So i have a case; coolermaster 450d, a Corsair RM650 PSU, and GPU is the RX560.
Asus said the Gpu will work.
I am hoping to buy the ASUS TUF B450 Pro Gaming MB(pc partpicker did have the micro version), A Ryzen 5 2600 processor and the cheapest memory i
found on the Asus QVL. it is CORSAIR CMK16GX4M2B3600C18 2x8gb
Using a 2nd gen ryzen, Asus says i can install my copy of windows 7 on it.
So in your opinion, will all these pieces work together?
Thank y'all so much.
I know you're right and I appreciate what you're saying. I would want to go ahead and buy my own full retail copy, not the oem and then do a fresh install. On Newegg, they want's a whopping 140bucks for home version on a flash drive. One amazon vendor has a Pro version for $125; do you think that's for real? thanks
It should be fine. If you have any problems Amazon will take care of you.
Reactions: ss_56
