Will these Parts Work together?
tinysolo1
6
I am building a semi-budget computer. Will these parts work together?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130833
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233170
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157372
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
These are the prices and spec and whatnot, and here is the list :
ASRock Z87 Extreme3 LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Desktop Memory Model CMZ8GX3M2A1866C9B
Antec EarthWatts EA-650 GREEN 650W ATX12V v2.3 SLI Ready CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
EVGA 02G-P4-2663-KR GeForce GTX 660 FTW Signature 2 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
These are the only parts i have speculations about
Yeah, that's a sweet board. It still does not work natively with the 1866 Mhz RAM, but again, anything north of 1600Mhz is bragging rights territory.
drewhoo
318
Yes! But make sure you realize that in order to take advantage of the 1866Mhz RAM, you will have to overclock it on that board, (it is not directly compatible). I don't recommend RAM speeds higher than 1600Mhz; the benefit beyond that speed hardly even shows up in benchmarks (which themselves exaggerate the benefits found in daily use).
Also, that motherboard is in the mini-ITX form factor, which is a little uncommon. The previous motherboard you listed was in the ATX form factor, which is much larger. That said, mini-ITX builds are awesome and the only major difference is that mini-ITX typically only have 2 RAM slots and 1 PCIe 3.0 slot, which I don't find to be a disadvantage for most gaming builds.
tinysolo1
6
I realized this and changed the link quickly in hopes you wouldnt see the mini. Here is the mobo that i wanted to be checked:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
Sorry for the mix up!
tinysolo1
6
Actually on newegg its shipping with a 8gb 1600 ddr3 memory model. Im probably just gonna buy another stick and save money XD
Thanks A lot for helping!!!
