Will these PC parts be compatible?
orlmente
8
This is my first time build for a budget gaming PC ($500) and I want to ask if its compatible and if it can run Battlefield 3 at a moderate setting.
http://pcpartpicker.com/p/LUK
CPU- AMD Phenom II X4 840 3.2GHz Quad-Core Processor
Motherboard- Asus M4A78LT-M Micro ATX AM3 Motherboard
RAM- G.Skill 4GB (2 x 2GB) DDR3-1600 Memory
Hard Drive- Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive
GPU- Asus Radeon HD 6570 1GB Video Card
Case- Rosewill CHALLENGER ATX Mid Tower Case
PSU- Cooler Master 500W ATX12V
Optical Drive- Sony AD-7260S-0B DVD/CD Writer
OS- Microsoft Windows 7 Home Premium SP1 (64-bit)
Mmm, Yeah but would you mind linking us to the Power supply? Because some of them are noobish even some of CM's...
So far everything works
Power Supply- http://www.newegg.com/Product/Product.aspx?Item=N82E16817171031&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-Power%20Supplies-_-Cooler%20Master-_-17171031&AID=10440897&PID=3938566&SID=
but will this pc run bf3 at moderate settings?
That is not a good power supply, It is not 80+ certified, Get this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207012
Power supply is the MOST IMPORTANT part of a PC...
And btw, I have a Pc with intel i5 dual core, 6GB RAM, and a RADEON 5470 and it cannot play battlefield bad company 2 on LOWEST SETTINGS without lagging. So i would say: NO that will BARELY play bf 3... But your processor is fine. (i would go with the i3-2100 though)...
AND YES!! GET THE HAF 912 CASE ITS AMAZING!!!!
Btw, The card you will need to play bf3 on moderate to high would be this: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
