Will these Rigid Water Cooling Parts go together
TheIcePhoenix
39
from FrozenCPU I cant seem to share the cart or I would. CPU will be Intel Core i7-5930K in a Tt Core X9 unless someone has a cooler case to go with? already have a 900D but im building a new EPIC pc and dont want to use the same case. thanks for advice@!
I don't know if all these parts will work together and need to be sure before I spend the money. So I thought I would ask you guys!
ex-tub-1022 XSPC High Flex PVC Tubing - 7/16" ID (5/8"OD) - Clear $2.50 $5.00
ex-tub-1892 PrimoChilll 1/2" OD Rigid Ghost Compression Fittings - 4 Pack - White $24.99 $24.99
ex-tub-1885 PrimoChilll 1/2" OD Rigid Ghost Compression Fittings - Single - White $6.95 $13.90
ex-tub-2551 PrimoChilll 1/2" OD Rigid Ghost Coupler Fitting - Single - White $9.99 $19.98
ex-tub-1855 PrimoChilll 1/2" OD Rigid Acrylic Tube - 1x 36" Single - Clear $9.99 $19.98
ex-tub-1870 PrimoChilll 1/2" OD Rigid Acrylic Tube - 4x 24" Pack - Clear
Add a Silicon Insert or Kit: Rigid Tube Silicon Insert-1' ($2.99)
$19.98 $19.98
ex-pmp-234 XSPC D5 Vario Pump Motor w/ Mount Ring - Single Edition $89.99 $89.99
ex-blc-1126 Bitspower Summit EF CPU Liquid Cooling Block - Intel LGA Series - Clear Acrylic (BP-WBCPUIAC-CUMBKCL)
@ TheIcePhoenix
In your original post list you show vinyl tubing and hard acrylic, you need to use one or the other?
You do know you have to heat bend and form hard acrylic tubing to fit, Right?
It is not an easy undertaking, some of the most experienced water coolers have had difficulty doing it.
And hard acrylic tubing takes hard acrylic compression fittings, and vinyl tubing takes flex tubing compression fittings, two completely different types of fittings.
I'm just relaying this information because your list has inconsistencies.
I was getting both in case the Hard tubing proved too much for me
