will these sma-rp antennas fit for my asus wifi pci-e adapter
djsioni
Commendable
Apr 8, 2016
158
and will it work with 5ghz frequency
only sais 2.4...
please help and thank you in advance <3
asus wifi adapter
ASUS PCE-AC55BT 802.11ac Wireless-AC1200 Bluetooth 4.0 PCIe / mPCIe adapter
sma-rp antenna
Netis PA109S 2.4GHz 9dBi Indoor Omni-directional Antenna
specs
windows 10
asrock fatal1ty b250 gaming k4 motherboard
intel i7 7700k 4.2ghz processor w/ hyper d92 cpu cooler
gskill-ddr4-2400 2x8gb (16gb kit)
evga supernova 650watt power supply
xfx 390 8gb graphics card
tp link pci-e wifi adapter >upgrading to asus wifi adapter
They are both rp-sma connectors it should fit. My power I means the output power of the card including the antenna gain. Things like mimo use the interference pattern between the antenna to transmit more data. This pattern is directly affected by the output power as well as many other things.
It is fairly cheap to try and if your problem is not enough signal it may still be faster even if the mimo is impacted.
Assuming you can remove the antenna, I have not seen that particular model. Pretty much everyone has moved over to the rp-sma connectors.
2.4g and 5g are pretty close in frequency. A antenna may be optimum at one frequency but the difference will not be huge at those frequencies. Most antenna manufacture have table that show the gain at a bunch of frequencies.
Now you may get more signal strength but the power and spacing of the antenna can affect the mimo ability so you can get slower speeds. This is not like the old days where only a single antenna was used. It is massively more complex now days.
sorry my friend im confused....
what i ment to say was "rp-sma"
will these rp-sma plugs work
are they the right plug??
will it fit ... sorry if i sound stubborn...
i have the space but what r u saying about power
