Will these system will fit into Corsair 400R?
Partpicker is supposed to check. But sometimes its good to double check whether the cpu cooler will fit and whether the graphics card will fit.
That's done by looking at specs eg http://www.corsair.com/en/carbide-series-400r-mid-tower-case -
max cooler height 175mm, maxg vga card length 318mm.
Then check against the cooler and graphics card specs -
Card - http://www.gigabyte.com.au/products/product-page.aspx?pid=5209#sp - 312mm long
cooler - http://www.pccasegear.com/index.php?main_page=product_info&products_id=27666 - 165mm
So both of those will fit OK
