Will these work together well in a build?
FunkeyMonkey
So, I'm new to the whole building gaming PC's thing, so I just wanna know if these items will be compatible and will work well together each other.
If you have suggestions as to what I should/could change, please leave a comment, but keep the items in the price range of the ones I have listed.
Thank You.
AMD FX-8320 FX-Series 8-Core Black Edition
http://www.amazon.com/AMD-FD8320FRHKBOX-FX-8320-8-Core-Black/dp/B009O7YU56/ref=sr_1_1?ie=UTF8&qid=1428226408&sr=8-1&keywords=amd+8320
ASUS M5A99FX PRO R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.amazon.com/M5A99FX-PRO-R2-0-990FX-Motherboard/dp/B008B6ONXK/ref=sr_1_1?ie=UTF8&qid=1428226470&sr=8-1&keywords=asus+990fx
Sapphire Radeon R9 270X 2GB GDDR5 DVI-I/DVI-D/HDMI/DP Dual-X with Boost and OC Version PCI-Express Graphics Card 11217-01-20G
http://www.amazon.com/Sapphire-Version-PCI-Express-Graphics-11217-01-20G/dp/B00B3WTWXU/ref=sr_1_1?ie=UTF8&qid=1428226584&sr=8-1&keywords=sapphire+radeon+r9+270x
And also, will this be a good enough case for these parts? lmao.
Corsair Carbide Series SPEC-01 Mid Tower Gaming Case CC-9011050-WW
http://www.amazon.com/Corsair-Carbide-SPEC-01-Gaming-CC-9011050-WW/dp/B00I6BJATW/
PCPartPicker part list: http://pcpartpicker.com/p/Jhg6dC
Price breakdown by merchant: http://pcpartpicker.com/p/Jhg6dC/by_merchant/
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($137.88 @ OutletPC)
Motherboard: ASRock 970 Performance ATX AM3+ Motherboard ($70.98 @ Newegg)
Video Card: Sapphire Radeon R9 280X 3GB Video Card ($189.99 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($44.90 @ Amazon)
Total: $443.75
Generated by PCPartPicker 2015-04-05 06:44 EDT-0400
the asrock is a new 970 chipset based mobo decent enough for the FX even for overclocking, also supports dual gpu and gives you the ability to ascend to R9 280x remaining at the...
Total: $443.75
the asrock is a new 970 chipset based mobo decent enough for the FX even for overclocking, also supports dual gpu and gives you the ability to ascend to R9 280x remaining at the same price $482.76 without the mail in rebates!
Thanks! So will the ASRock motherboard be a better choice rather than the ASUS?
Also, do you think a CPU cooler may be necessary?
