Will these work with my PSU?
Chuckles1991
I have an:
Antec HCP-850 Platinum 850W ATX12V / EPS12V Yes Yes 80 PLUS PLATINUM Certified Full Modular Active PFC Power Supply - Intel Haswell Fully Compatible
Will either of these work with my PSU?
http://www.newegg.com/Product/Product.aspx?Item=N82E16812527003&cm_re=evga_individually_sleeved-_-12-527-003-_-Product
https://www.nzxt.com/product/detail/58-premium-cable-starter-kit.html
Looking for good individually sleeved cables to go into my set up to make it a little cleaner looking inside the case. So if anyone has any recommendations then let me know !!
I would venture that no, those won't work for your PSU. I might suggest looking at offerings from IceModz who have an HCP model (1300W version) set. They seem to be the only ones (from what I found) that'll do Antec PSU's at all. They seem to have a chat system so you can chat with them to see what they can do for you. If I find other options, I'll post them but that's all I was able to find through my sources.
