Hey everyone,
I've had this machine setup for me by a friend, and am looking to upgrade it for Battlefield 3 and other upcoming games. I just wanted to run this by the community to see if my upgrades are "compatible" with my current setup. My resolution is 1680X1050
My setup consists of:
MoBo: GIGABYTE GA-MA785GN-US2H (Specs can be found here:http://www.gigabyte.com/products/product-page.aspx?pid=3447#ov)
CPU: AMD Phenom II X4 955 @ 3.22GHz
GPU: BFG NVidia GeForce GTS 250
RAM: 4GB (2x 2GB)
PSU: Enermax Tomahawk ETK500AWT 500watt
I beleive that's all the specs needed in order to answer the following questions.
1.) The Graphics Card I plan on upgrading to is the: EVGA GTX 560 TI (http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130604) Will it work with my current setup with no problems? Will it fit into my mobo correctly, and will it receive enough power?
2.) I know this is the Graphics card subforum, but I'm assuming you all know a thing or two about RAM 😉 . I want to upgrade to 8GB of RAM. I know that my mobo will only support DDR2 RAM, and that I only have two slots left. Will these sticks of RAM work with my system? (http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231122)
3.) I plan on overclocking a little later, but do you think with these upgrades i'll be able to run Battlefield 3 with high settings at a good framerate?
Sorry for the huge diatribe here, but I do need help. If these parts will not work, if you could please link or name any parts that will work.
Much Thanks!
Kayos340
RAM: 4GB (2x 2GB)
Much Thanks!
Kayos340
