Hello! I just built my first PC yesterday, and its working absolutely great so far. The only thing I apparently haven't done much research on is the case, which is a Cooler Master Pro MasterBox 5 RGB. I heard four rgb fans, around 80 dollars, and I was hooked. It got decent reviews, so I figured why not. However, apparently this thing's airflow is quite bad, especially for high-end builds like mine :
Intel i7-9700k
Nvidia RTX 2070 Super (MSI)
MSI Z390 Gaming Pro Carbon AC
Thermaltake ToughPower Grand 850W Gold
16 GB RAM
500 SSD, 1TB HDD
Cooler Master Hyper 212 RGB Black Edition
Unfortunately, the store didn't have the 2070 super yet, so they gave me a 1060 to set up my computer and fiddle with it for a few days till the 2070 super arrives, so I cant really find out how high the temps will be until a few days. I have seen a lot of people build this case with 2080s and i7-9900k on pcpartpicker and all, and they claim it's perfect. But a lot are also saying the opposite, especially since this case doesn't support any fans at the top, and the front panel is directly facing three fans, making airflow not that great. Some suggested to take off the front panel while gaming.
Should I be worried? And if I do have to take off the front panel, wont that expose it to dust? Maybe I can make holes in the front panel or something? And if it helps, I'm using the NZXT Cam app which shows that the CPU (in minimal load) to have Temps ranging from 35-42. Sorry I've been a laptop guy for over ten years now...
Thank you!
Intel i7-9700k
16 GB RAM
500 SSD, 1TB HDD
Thank you!
