Will this build work, and how well?
JesseNeedsHelp
Hello,
This is the system
Case: Fractal Design Define R4 Black Pearl
Motherboard: Gigabyte GA-Z77X-UD3H LGA 1155 Intel Z77
Graphics Card: EVGA Geforce GTX 680 2GB
Power Supply: Corsair HX Series H750
Processor: Intel Core i5-3570K ivy bridge 3.4GHz / intel hd grapgics 4000
RAM: Corsair Vengeance 16GB (4 x 4GB)
SSD: Samsung 840 Series 2.5" 120GB SATA III
HardDrive: Western Digital Caviar Black 2TB
Cooler: Corsair Hydro Series H80 (plan on doing over clocking)
It's good, but get a 7970. It is as strong as the 680, and it can destroy it in overclocking. Or you could just get a 7970ghz which is flat out as strong as a 590. You probably don't need watercooling even if overclocking, but it will still be way quieter. The get 2x4gb ram.
This is my first computer build, and there are so many brands of 7970's which should i buy.
