Will this build work and run smoothly together?
DangeRussWest
22
I'm just about to order these parts. will these work well together? I was also wondering if I could downgrade my case to something more around $80-$120, or am I better off sticking with the one I have now.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor
CPU cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
GPU: MSI GeForce GTX 980 Ti 6GB Video Card
Motherboard:MSI Z97-GAMING 5 ATX LGA1150 Motherboard
RAM: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory
PSU: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Hard Drive:Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Case: Corsair 750D ATX Full Tower Case
Thanks
Get the CRYORIG H7 instead of the Cooler Master 212
Get the Enthoo Pro instead of the 750D
Get the Asus Z97-A instead of the Gaming 5
I hope you have enough monitor to warrant a GTX980ti
Thanks for your quick response. I have looked at the H7 and it was out of stock on the sites I checked. Is it a lot better than the 212? For the motherboard, what advantages does the asus Z97-A have over my current one. This is my first real build so I'm not too experienced yet.
As for the 980Ti, I will be running a 1080p 120hz monitor, maybe two. The only reason I don't want a 970 or a regular 980 is that I might switch over to 4k in the future. Is that overkill? Thanks.
Alright, I'll look into it then. Another thing I was worried about was if the CPU cooler will fit in the case and not affect the RAM. I've heard the 212 is pretty big so I was thinking of waiting for the H7 to go back in stock or just go for the 212 anyway. Any suggestions? One last thing, do you think I might need another case fan? Thanks for your help :)
Okay, sounds good. Thanks for your help, I appreciate it
Latest posts
