Will this build work? (First time build)
67juniorleon
4
Hey guys,
I'm pretty new to the forum and to building a PC in general, wondering if this build would be compatible and things like how hard it would be.
Possible Specs:
-https://www.amazon.co.uk/gp/registry/wishlist/7CUPUJNVY0UK/ref=nav_wishlist_lists_1
Thanks in advance.
Get the cheaper Sapphire RX 460:
https://www.amazon.co.uk/Sapphire-Technology-11257-00-20g-460-1750-MHz-GDDR5-PCI/dp/B01J1J7WPG/ref=sr_1_2?s=computers&ie=UTF8&qid=1493850221&sr=1-2
Upgrade PSU to the Corsair CXM 450W:
https://www.amazon.co.uk/Corsair-CP-9020101-UK-CX450M-Bronze-Certified/dp/B01C3FFOHS/ref=sr_1_1?s=computers&ie=UTF8&qid=1493850387&sr=1-1
>>> The Corsair VS is notorious for dropping the 12V rail under load and shutting down system. Avoid them at all cost.
The BitFenix case is basic but functional, add a bit more to get the Antec GX 200 for a more modern interior design and a bit more space to run cables.
Find a DDR4 module instead of DDR3 like:
Crucial Ballistix Sport 1x8GB 2400 DDR4 or Crucial Ballistix...
Crucial Ballistix Sport 1x8GB 2400 DDR4 or Crucial Ballistix LT 1x8GB 2400 DDR4.
>>> You've selected the 240pins DDR3 that is incompatible with Kabylake+ H110/B250 MB; they'll need 288pins DDR4.
320GB HDD is very small, you'll want a minimum ~500GB HDD to get going.
And lastly, for the most trouble-free experience, try to get a B250 motherboard instead of H110 since they are guaranteed to be compatible with the Pentium G4560. Ex: ASUS B250M-K or ASUS B250M-A
>>> H110 MB will only POST with the BIOS released back in Oct 2016; at this point it's likely that most H110 board will already be those that were manufactured after that date and therefore already carry the updated BIOS; but go for a B250 MB to be absolutely sure that the MB will be compatible with the CPU.
