Will this build work together?
Jason_134
8
I have been looking to get an entry level game pc. I actually moved over from console's so forgive me if I'm asking stupid questions, I just want to make sure this will all work.
Here's the build im planning on
MoBo: ASRock 960GM-VGS3 FX MicroATX
CPU: AMD FX 4300 Black Edition
GPU: MSI N750Ti TF 2GD5/OC - Does this version need the 6 pin power connector or does it take the power directly from the MoBo like the others?
RAM: 8GB DDR 1600 MHZ
PSU: MS-Tech MS-N450 VALUE Rev. B 450 watt
HDD: Toshiba MQ01ABF050 500 gb
Case: Spire Ridge 6601 Midtower
Fans: 3x Arctic Cooling ARCTIC F12
CPU Cooler: ARCTIC Alpine 64 PLUS
Sorry if I included to much but I figured I might just post every component here. As far as I can tell it should all be compatible. Is the airflow sufficient enough? I went with the cheapest case I could find. Also went with the cheapest micro ATX motherboard that supports an AM3+ socket cpu.
I didn't wanna go to cheap with the PSU because I've read that that might be bad so I didn't take the cheapest one but it's still pretty cheap.
In total this costs me around 400 euros which is about all I can spend right now. Will this do for games like BF4, GTA V and BO3?
Thanks in advance
i would like you to refer to pcpartpicker.com , and ready your build.It shows only the Components that are compatible with each other.
Thanks and hit the best solution if you like the answer.THANKSS.
