Will this build work with no problems
Heritic
Commendable
Feb 23, 2016
8
Hey guys I'm currently building a new pc from scratch and I would like to know if this build will work. I'm sorry if this troubles you
BenQ RL2455HM 24"
SanDisk SSD Plus 120GB 2.5"
G.SKILL RipjawsX 16GB (2x 8GB) DDR3
1600MHz
Seagate ST2000DM001 2TB Barracuda Desktop HDD 3.5” 7200RPM
Thermaltake SMART 650W 80Plus Bronze Power Supply
Deepcool Kendomen ATX Mid Tower Case - Red
Gigabyte H110M-S2PV DDR3 LGA 1151 Micro ATX Motherboard
Intel Core i5 6600K Quad Core LGA 1151 3.5 GHz Unlocked CPU Processor
Gigabyte GeForce GTX 970 Windforce OverClocked 4GB Video Card GV-N970G1-4GD
Your help is much appreciated thanks!
Yeah you could get the H170, but only the Z-series (Z170 in this case) support overclocking. So yeah, the Gigabyte H170-HD3 is a decent board, but it doesn't support overclocking.
Looks good although I don't see why you'd get an unlocked CPU with a low end motherboard that doesn't support overclocking (unless you plan to upgrade later on of course, in which case it might be wise to get a board that supports DDR4). Also, make sure the DDR3 you want to get runs at 1.35V instead of the standard 1.5V.
Gigabyte H170-HD3 LGA1151 Motherboard
how about that. ( I'm changing my ram to ddr4 (4x4) g.skill ripjaws
Gigabyte GA-Z170-HD3 LGA1151 ATX Motherboard so this?
