Will this cable configuration work?
Mike226
17
So i have a Corsair 600W CXM and i want to power two Sapphire R9 270's (For Scrypt mining not gaming). Each card needs a single 6 pin pcie cable. The power supply comes with 2 pcie 6 pin plugs but they are part of the same cable if you know what i mean, as in, one 6 pin, and then some cables coming out of it and another 6 pin along the line. All i'm wondering is can you have two different cards on the same cable or can i only have one card on the cable line and then get a 6 pin power source from a converted 4 pin molex connection.
Thanks
Mike
