(email to palit which recieved worthless reply)
Is this card
http://www.palit.biz/palit/vgapro.php?id=1692
or any of your other GTX cards that are two lanes wide thin enough to get airflow if there is another card with a circuit board about the same size in the 3rd slot? For example in my system, about 4 months ago I bought a fairly standard GTX460 from another company, I was able to get it into my system without a problem, but I noticed after it was inside, that the amount of space in between the fan on the card, and the back of the next card (a 6 inch long x-fi sound card) was about 1mm. When I turned the system on I promptly found that within 10 minutes of playing any game, the card was at 75 degrees C, and it sounded like when you stick your hand on the tube of a shop vac, where it sounds like a jet engine winding up, and then like it is going to break.
I wonder if your card here, or any other of your performance cards are thin enough, while still being two lanes wide, to get sufficient airflow with another sizeable card in the very next slot after the video card
And to the tomshardware community, if not this card, do you know of any that would suit my need?
Is this card
