I am looking to buy the Corsair Carbide Air 240 Cube Case. It says it has a GPU cooler restriction of 120MM and I'm not sure which way this measurement is meant. Does anyone know if it will fit? I tried measuring it from the GPU upwards and it seems to be about 120MM exactly but I'm still not sure again.
Dimensions of cooler (Hyper 212 Evo):
Width: 8 cm
Depth: 12 cm
Height: 15.9 cm
The Case's site states: Maximum CPU Cooler Height: 120mm
Any help would be appreciated
Thank you!
Width: 8 cm
Depth: 12 cm
Height: 15.9 cm
Thank you!
