Will this case work for my build?
Wlau21
54
I'm getting it 3570k and a pro4-m(mATX) motherboard and I am wondering if this case will work. I also got this power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817341050.
The reason i chose this case is because I like how extremely small it is. This raises the question of how hot my computer will run though because of how small it is. I will not be overclocking until maybe down the line(2 years). I will also be putting a 6850 or 6870 GPU in this case. Will temperature be fine and everything run fine in this case?
case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147122
Your choice of power supply has been deactivated.
It will work. But selecting this small case will put you in a very limited upgrade plan. PC Cases unlike CPU & graphics cards never get outdated easily so it may be good to invest in a good one today. After all, are buying yourself good CPU's & GPU's so I believe it is worthwhile for you to invest more on the case as well.
The quality of your other parts (very good) do not seem to match the quality of the case (poor). It might be OK - just.
Your PSU - OCZ ZT Series 550W is a great choice & well matched to your parts
But it's also one part you where you can spend a bit less and then spend a bit more on the case. Like OCZ 550W non-modular or OCZ ModXStream Pro 600W modular.
My 2nd choice for case was the NZXT Vulcan.
The OCZ ZT 550W was actually a newegg shellshocker deal yesterday and I got it for $40(including mail in rebate). I thought it was a pretty good deal and I read that OCZ will go out of their way to honor their rebates if the rebate company does not.
Great deal there. At that price it was a steal.
Just pay close attention to the rebate directions and keep copies - just in case.
What about this one? http://www.newegg.com/Product/Product.aspx?Item=N82E16811352009
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119193&Tpk=cooler%20master%20341&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4003003&SID=ntlerypgd0vava
I like these cases more because i'm going for small form factor. Those are exceptionally long or tall for matx.
Fractal Design Core 1000 mATX Compact Case video review
http://www.youtube.com/watch?v=wfwrubJC3II
Fractal Design CORE 1000
http://www.techpowerup.com/reviews/Fractal_Design/Core_1000/
A couple things to keep in mind.
Both cases have a single 120mm fan. You'll want to monitor system temps during gaming to test if you'll need a 2nd fan or not.
Check the placement of the USB ports, power switch, etc., to make sure it's compatible with how you plan to have your case situated.
it looks like the coolermaster has better airflow potential ..Only comes with a single 120 mm fan in the exhaust location but has locations for a 120mm in the front ( intake ) location as well as two across from the gpu area ...
