Will this components work fine?
Dragos Romaniuc
17
Hello, guys!
My components just arrived:
Case: Zalaman z11 neo
Psu: Super Flower Golden King Pro 600W 80+ Platinum
CPU: i7-4790 (non-K)
Motherboard: MSI H97 PC MATE
RAM : Balistix Sport 2x4Gb 1600MHz 1.5v
HDD: WD 1 Tb 7200rpm 64mb cache/buffer
GPU: Integrated (HD 4600)
Total : 800$
My questions are:
1. Are my components 100% compatible?
2. Will this proccesor (i7 4790) run on MSI H97 PC MATE without a bios update?
Thank you!
Yes they're completely compatible and no, you won't have to update the BIOS.
What is this PC for?
If you're going to game with it you're going to need a dedicated GPU... On-board can't handle much.
If not, you're absolutely fine.
