Okay, so at first I was planning on going with the i5 8600k than a little bird told me that I should just go with the i5 8400 unless I was planning on overclocking, which I wasn't.
I then learned something called turbo mode for some Intel CPUS. Obviously the CPU is compatible and I know that it is dependent on the cooler to keep up faster speeds and so on.
So my question is, will the cooler I picked out be able to sustain good speeds in Games?
Cooler: https://pcpartpicker.com/product/93Crxr/cryorig-cpu-cooler-h7
So if someone could tell me that this will work well or if I need to upgrade that would be awesome (Though I also saw on a other forum that basically any non stock cooler will be fine.)
Also a bonus thing for any very helpful people.
I'm new to the PC master race and one thing that I don't super understand is stuff like running GHz on all cores? and if I really need some Ghz on the CPU? How can I control all the cores? If someone could point me or help me in that sense that would be amazing.
Thanks.
Thanks.
