will this cpu cooler fit on my motherboard?
yes it will fit the chassis. here is your cabinet's cooler support list: http://uk.pcpartpicker.com/parts/cpu-cooler/?compatible_with=corsair-case-cc9011038ww.
Check whether the V8 come with a pre-applied thermal compound and then you may drop the AS5 for now.
the build looks awesome, however for a 760 SLI, 700W psu is recommended. consider the links below
http://www.realhardtechx.com/index_archivos/Page362.htm
http://www.tomshardware.com/answers/id-1872646/gtx-760-sli-psu-requirement.html
good luck
-Satyam
good luck
-Satyam
Thx for the quick response, but i have just configured an other build. Its similar to the one previous, but any way can u take a look pls? Thx 😉
http://uk.pcpartpicker.com/user/Yasin/saved/3UQk
