Will this CPU cooler fit ?
dakata1337
Commendable
Feb 11, 2018
17
So i have a Fujitsu Esprimo 710 e85+ and i want to change the default cpu cooler to the Deepcool Gammaxx 400, and im wondering if it will fit.
Case dimensions (W x D x H) 175 x 419 x 395 mm
6.89 x 16.5 x 15.56 inch
https://www.google.bg/search?biw=1680&bih=939&tbm=isch&sa=1&ei=Y5PAW67cNeTKrgSWnaqQCg&q=fujitsu+esprimo+p710+&oq=fujitsu+esprimo+p710+&gs_l=img.3..35i39k1l2j0i30k1j0i24k1l5.11402.11759.0.11982.3.3.0.0.0.0.157.418.0j3.3.0....0...1c.1.64.img..0.2.279....0.TjhrPhdkVn4#imgrc=_jPBVeG7NrLpbM:
https://www.google.bg/search?biw=1680&bih=939&tbm=isch&sa=1&ei=Y5PAW67cNeTKrgSWnaqQCg&q=fujitsu+esprimo+p710+&oq=fujitsu+esprimo+p710+&gs_l=img.3..35i39k1l2j0i30k1j0i24k1l5.11402.11759.0.11982.3.3.0.0.0.0.157.418.0j3.3.0....0...1c.1.64.img..0.2.279....0.TjhrPhdkVn4#imgrc=nVKuNdJaLKPMnM:
This is the stock heatsink:
https://www.google.bg/search?biw=1680&bih=939&tbm=isch&sa=1&ei=x5TAW8GeGaP5qwGH677oBg&q=fujitsu+esprimo+p710+heatsink&oq=fujitsu+esprimo+p710+heatsink&gs_l=img.3...5355.6722.0.6905.8.8.0.0.0.0.185.882.0j7.7.0....0...1c.1.64.img..1.0.0....0.9oo-iZYeEDs#imgrc=HEd3C5_mq3Ze3M:
Risky, 155mm tall cooler, the case is just about exactly that wide (Using the 5 1/4 (146.1 mm) bay as a ruler. And the 175mm width dimension. If you include the motherboard and CPU thickness I would say no. You probably wouldn't be able to put the side panel on.
See if one of these is available to you:
https://pcpartpicker.com/product/hyQRsY/be-quiet-pure-rock-slim-351-cfm-cpu-cooler-bk008
https://pcpartpicker.com/product/LPVBD3/cryorig-cpu-cooler-m9i
Or you can go with a more standard down draft cooler like the Cryorig C7.
