I was wondering if the following CPU fan: Cooler Master RR-212E-16PK-R1 Hyper 212 Evo
Would fit onto the following Motherboard: GIGABYTE Z87X-UD4H Ultra Durable
If you could help it would mean I can order.
Thanks
Thom
Yes it does! Your mobo socket is 1150, and the Hyper 212 fits on that!
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
That mobo has LGA 1150 socket, which is listed as a supported socket on the product page.
Thanks
Thom
You're probably better off just looking at the case specs on the manufacturer's website rather than trying to measure yourself. Also, the width of the case is not the same as the maximum CPU cooler height (not sure if that's what you were measuring).
