Will this DVI-I to VGA converter work?
The Kwak
Commendable
Mar 19, 2016
6
I am buying a new graphics card (Nvidia Geforce GTX 960 4GB) but I only have VGA monitors. By using this cable would I be able to use one of my monitors with the graphics card? I know that DVI is digital and VGA is analogue, but this listing claims that it will convert the DVI signal to VGA. I don't know much about this so I don't know if I should trust this, because I've heard that a lot of cheap adapters don't actually convert the digital signal to analogue.
http://www.ebay.co.uk/itm/High-Quality-5M-VGA-to-DVI-I-Cable-Converter-Monitor-Adapter-Lead-24-5-PC-DVI-UK-/131329476438?hash=item1e93d8c756:g:NAUAAOSwZkJUSSNl
If this won't work, can you send a link to something that will? And I do not want to buy a new monitor at the moment so please don't suggest that.
Thank you very much! :)
I won't be plugging in a second monitor to this graphics card so that's perfect!
