Will this fit in a slim ATX case?
dansk90
I want to build a low energy system that is under $800, so I put together the parts and was wondering if I could put this in a slim atx case because I would rather have that unless someone says otherwise.
Here is the link for the parts, ignore the case/motherboard/power supply/keyboard http://pcpartpicker.com/p/qQ3smG
To fit it in a slim atx case you would need to get an itx motherboard or micro atx motherboard(whichever fits the specific case), but you would also have to get a low profile video card. The 750 and 750ti are supposed to come out in that size soon, but I haven't seen any at major retailers yet and they'll most likely come with a $20-$40 premium. That size case would seriously limit your upgrades later on also, because normally there aren't even cards above $80 or so in that size.
One option might be to just get the smallest full size case you can find. I've used this one before without any problems and it fits a full size ATX motherboard, video card, and full size ATX power supply, but it's really small in size...
It depends on the specific case.
If you're going for low energy, the Xeon is one of the less efficient Intel CPUs available for it.
I do quite a bit of video editing so I wanted the reliability with hyperthreading which costs less than the i7. If I may ask, what will a more suitable combination be that won't increase in the price dramatically while possibly fitting it into a slim atx case? I do want to use it for gaming as well, but I'm not the type of person who cares for ultra settings or overclocking.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119262
Another option might be something like this. It requires a mini-itx board, but it fits a full size video card and full size power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119261
Alright then, if the graphics card of the current choice won't fit then that answers my main question. But I would like to know if there is some other cpu + gpu combo that you guys prefer that is just as cheap.
