Question Will this GPU work for my system
May 28, 2019
35
Hi! I was going to buy a GTX 1650 fron Zotac and install it into my system, but it has a low wattage power supply(180 watts), the gpu only needs power from the pcie rail, much like a 1050 or 1050 ti, has anyone had any success with any of these cards in this system. The model number is HP Pavilion 590-p0020
Eximo
Herald
180W is risky. I believe I have looked up that model before and it really does have close to a 180W rating.
Even if we assume a maximum of 75W from the GPU, and 65W from the CPU, that is 140W, and we haven't looked at the CPU fan, case fan, hard drive, and any peripherals you plug in.
Any long gaming session is going to heat the system up, and the efficiency on the supply will worsen. Best case it works for a year, worst case it blows up during a long gaming sessions and takes the computer with it.
If you must keep the HP chassis, buy this:
https://parts.hp.com/hpparts/Search_Results.aspx?mscssid=0BDFB89E77A34CFDA3C3BE81DA72C63A&SearchIn=PartNumber&SearchPN=L03980-800
A 310W supply that should fit in there.
Otherwise, it is best to look at getting a new chassis, a standard ATX power supply, and an adapter cable to plug it in. Not sure if there is an adapter for this relatively new model, but there might be.
Thread starter Similar threads Forum Replies Date
M Prebuilt & Enterprise 6
