Will this Graphics card get me 60+ fps medium settings for minecraft
ColaBoy
5
the graphics card i am planning on getting is a MSI ATI Radeon HD6450 1 GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card R6450-MD1GD3/LP heres the link http://www.amazon.com/dp/B004X6ABTM/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1P4PFQ1YHCHE4&coliid=I2RVGWDC3W8V95 i want to know if this will get me better fps right now on my pc i get 30-40 fps mainly and using low settings with optifine sometimes 60+. I use a hp pavilion slimline s5310f heres the link http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01949171 please help and give me feed back if this graphics card will help me
will i get at least 60+ fps with low settings? and i also record with fraps
Can u recommend a CPU thats is 60 or under please thats good
The best CPU i can come up with under that price range are Intel Pentiums, they have decent frequency and are dual-core.
Specifically the Intel Pentium G3240 or the Pentium G3420.
(Under 60 Euros i assumed)
EDIT: I just checked and if you might want to spend 10 Euros more you could get the Pentium G3258 Anniversary Edition.
The difference is that that one has an unlocked multiplier, wich means you can overclock it to get more for your money.
That is only if you are interested in overclocking though.
Oh yes, damnit.
I didn't notice he put his PC specs there aswell, only looked at his last question about a good CPU for 60 bucks...
To answer his question though, no, for AM3 there isn't anything decent under 60 Bucks, be it Euros or Dollars.
