Will this graphics card run on my power supply?
WrekCreation
95
will this graphics card run on my power supply? http://www.newegg.com/Product/Product.aspx?Item=N82E16814161315&cm_re=hd_4670-_-14-161-315-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3899435&SID=skim1402X558040
On my power supply there are 2 rows, 1 says 300watts on the left of the margine, and the other is 400watts in the same colunm directly undernethe the 300watts. Is it 300 or 400watts??
And here is ALL of my system infomation.
apopogies for all of this.
System Information
Time of this report: 11/14/2010, 18:53:41
Machine name: HOME-C7076E4EBD
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.100427-1636)
Language: English (Regional Setting: English)
System Manufacturer: Biostar
System Model: TF 570 SLI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+, MMX, 3DNow (2 CPUs), ~2.4GHz
Memory: 3072MB RAM
Page File: 622MB used, 4335MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 210
Manufacturer: NVIDIA
Chip type: GeForce 210
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0A65&SUBSYS_00000000&REV_A2
Display Memory: 512.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.9045 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/15/2009 01:39:49, 5845632 bytes
WrekCreation
95
You really think anyone will want to read your essay long system information.As for your answer post a pic of your psu.
Sorry just thought you gise would maybe kno where to look.
ok, but now how do i insert an image?
WrekCreation
95
Thanks man, but if you check the specs on my link, it says minimum 400w.. and im pretty sure mines 350w.
WrekCreation
95
Thanks alot.. :bounce:
That helps me out quite abit.
You right i should buy a better card than the HD4670 but i simply am low on cash at the mo and im heading off to namibia on the 3rd :)
would you say the HD4670 is a card that can handle games like gta iv on high res without any lags..??? if you look at my system info ive got 3GB RAM and efficient memory...
