Will this Graphics card work with my system
WrekCreation
95
Hi there
Will this graphics card work on my system Palit Nvidia GTS 250 1GB 256bit Graphics Card ?
Time of this report: 11/14/2010, 18:53:41
Machine name: HOME-C7076E4EBD
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.100427-1636)
Language: English (Regional Setting: English)
System Manufacturer: Biostar
System Model: TF 570 SLI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+, MMX, 3DNow (2 CPUs), ~2.4GHz
Memory: 3072MB RAM
Page File: 622MB used, 4335MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
Card name: NVIDIA GeForce 210
Manufacturer: NVIDIA
Chip type: GeForce 210
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0A65&SUBSYS_00000000&REV_A2
Display Memory: 512.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.9045 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/15/2009 01:39:49, 5845632 bytes
Are you asking if you can add that card to your current setup so it is SLI? Or are you asking if you can replace your 210 with a 250?
If you want to replace the card it will absolutely work.
If you want to run SLI I believe you have to have matching model numbers.
If you are planning on replacing the Graphics card, then yest it will work without no problem.
However, if u plan to SLI the GTS 210 And 250, then it can't be done. Because to SLI u will need the same model graphics Cards Like 2 x GTS 210 Or 2 x GTS 250.
Hope this helps.. :)
