No.Will this nvme work at full speed with my motherboard?
Gigabyte H410m S2H
No. It will work at half the advertised speed because your motherboard only has a PCIe x2 interface for the M2 slot.Will this nvme work at full speed with my motherboard?
Gigabyte H410m S2H
No.
PCIe 3.0 x2 is "slower" than PCIe 3.0 x4.
Theoretically, 1/2.
But....what will this be used for?
Unlikely you would see any real difference, and NO need to change a bunch of parts just to meet the full speed (PCIe 3.0 x4) of the 970 EVO Plus.
Per the manual for the motherboard, here, it states that the M.2 will operate at PCIe x2 meaning it's a PCIe 3.0 x2 slot. No it won't run at full speed. If you want that from your Samsung 970 Evo, you will need to look into a B460 chipset board.
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280 SATA and PCIe x2 SSD support)
spec sheet says the above.
I think the 970 Evo Plus is third gen, so no.
Your motherboard port is the limiting factor.so is there any other nvme that it will work better with my motherboard or the samsung 970 evo plus is my best choice even it well not run at full speed?
Yeah i already know that now thanks to you, but should you recommend me another nvme or samsung 970 is just fine?Your motherboard port is the limiting factor.
A PCIe 3.0 x2 drive will be no "faster" than a PCIe 3.0 x4 drive like that Samsung.
What you should really be chasing is reliability.
There, Saamsung is the general winner.
The 970 EVO or EVO Plus is as good as it gets.Yeah i already know that now thanks to you, but should you recommend me another nvme or samsung 970 is just fine?
ok thanks you helped me alotThe 970 EVO or EVO Plus is as good as it gets.
No.
Theoretically, 1/2.
What if i used sata SSD instead of Nvme?1 x M.2 connector (Socket 3, M key, type 2242/2260/2280 SATA and PCIe x2 SSD support)
See these:What if i used sata SSD instead of Nvme?
Yeah i alreaWhat if i used sata SSD instead of Nvme?
