Will this Pc build work out?
soniccaner1
283
http://prntscr.com/7tvkci
^ is what i have so far
Will this pc build work out?
Is der anyways to make it cheaper etc. I am taking the cpu from my 620s inspirion -which i have been told will work but hold back on everything.If u guys can find a really cheap cpu then please tell me.
If u cna make this build cheaper please do thank you
also do i have the correct version of the gtx 760 XD i want it to be the best one
Furthermore if there is anything i am missing out on please tell me and give me a suggestion - please make it cheap as always XD
Please skype me it is soniccaner1
I need help :/
Dude can u help me out and skype with me i am really confused
my skype is Caner Tasdemir
Uk
Tiger emblem
write soniccaner1 instead if u can't find it
i really need help and confused
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135343
This motherboard will do you just fine and it's much cheaper than the one you have chosen. I'm not sure if it's available in Britain, but it's not hard to find a cheap motherboard. Just search for available motherboards that have socket LGA 1155. Pick one of the cheaper ones, and then check the motherboard's website to make sure that your CPU is compatible.
Could you just skype me or teamspeak or whatever idk which one to go for etc which gtx 960 which cpu etc I need this XD
Keep your current CPU and get a $60(38 gbp) motherboard. A modern day i5 paired with a good motherboard can cost over $300 and a Pentium G3258 paired with a cheap motherboard will cost over $120 and it won't perform as good as your current CPU and a cheap motherboard.
As far as the graphics card, you can find a GTX 960 for less than the GTX 760 you have chosen. I don't live in Britian, so I don't know what's available to you, so I recommend looking up the GTX 960. If it's cheaper, get it. If not, then go with what you have. It will play modern games at good qualities for a few years.
Your RAM, case, and power supply look good.
Which Cpu the one that i have been refered or the one on my 620s inspirion also don't i need a cpu cooler?
