Will This PC build Work well?
dallaseatsfood
14
so i've picked out the components and i just want to make sure that everything will work together and fit in the case. If you have any suggestions please let me know! I'm trying to keep it under $1000.
CPU- Intel Core i5-4670k quad-core 3.4GHz 6mb cache
GPU- MSI NVIDIA GeForce GTX 760 OC 2GB GDDR5
Motherboard- MSI Z87-G41 PC MATE
RAM- ADATA USA XPG V2 series 8GB DDR3 1600 PC3 12800(4GBx2)
PSU- XFX PRO 650W Core Edition 80+ Bronze ATX 650
Hard Drive- WD Green 2TB Desktop hard drive 3.5 inch SATA II, 64 MB cache
Optical drive- LG optical DVD Drive
Fan- Cooler Master Hyper 212 EVO
Case- NZXT Guardian Black SECC Steel Chassis ATX Mid Tower Case 921RB
Total Price - $984.50
Hi dallaseatsfood
looks like a good build , cpu and mobo compatible
quality psu with high grade japanese capacitors and more than enough power for your 760 and cpu and overclock if you require
your 1600mhz ram will work with your board
rest looks fine :)
Thank you!
