[SOLVED] Will this PCI-e videocard work in this base system?
Mar 26, 2019
Im currently looking to buy a Dell inspiron desktop and install a GTX 1050TI into it. for some light gaming/videos/etc
However i noticed on the card it recommends 300w PSU.
The Inspiron listed has a 290w PSU.
Will i get performance drops? or should it all be okay anyways?
I also was wondering about the metal slot if it will fit ETC.
If anyone can provide any helpful information before ordering i would be very appreciative.
This is the card - https://www.newegg.com/Product/Product.aspx?Item=N82E16814137303&ignorebbr=1
And this is the system. - https://www.newegg.com/Product/Product.aspx?Item=9SIA29P8TE0796&ignorebbr=1
