Will this pc's parts work together or will i have to scrap the items?
Alex Shahdoust
8
These are my pc parts
Im sorry before hand for my unknowledgness this is my first time building a pc myself.
CPU
Intel Core i5-4670K 3.4GHz Quad-Core Processor
CPU Cooler
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard
Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard
Memory
Corsair Vengeance 8GB (2 x 4GB) DDR3-1866 Memory
Storage
Samsung 840 EVO 120GB 2.5" Solid State Disk
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card
MSI GeForce GTX 770 2GB TWIN FROZR Video Card
Case NZXT Guardianblue
Power supply
Corsair RM 750W
And does water cooling work with this setup and what systems should i use?
Any critisism would be great :)!
Looks great, but you won't be needing the Corsair RM 750W.
Your build will probably only pull about 600W, and with overclocking 650W should be fine.
The only time you will want a 750W PSU is if you are going to be running a SLI setup with the 770.
Here's a good alternative I recommend very highly.
For a possible upgrade to SLI I would recommend this PSU
Power Supply: SeaSonic G-750 750W 80+ Gold Certified Semi-Modular ATX Power Supply ($94.99 @ Newegg)
Total: $94.99
(Generated by PCPartPicker 2014-05-09 19:32 EDT-0400)
But if you feel like you're on a really tight budget, you could save a few bucks and go with:
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($79.74 @ Amazon)
Total: $79.74
But in the end, I recommend that 750W Seasonic 80+ Gold Semi-Modular.
(If you've already ordered the parts and cannot go back, then keep your Corsair RM 750, it will work good with your build.)
Most rational people will admit that Intel and AMD both have their benefits. The 4670k is a great CPU. Anybody who says otherwise is... don't listen to people who say that. The Seasonic and XFX power supplies are great, but 750w is more futureproof. Personally I like to not upgrade my power supply every time I need an upgrade.
No problem. For your other parts, I can't recommend anything. What you've selected is top notch.
By the way, can I ask what was your budget for this build?
I've build you basically a whole new system within your budget, which should perform massively better in games due to the upgrade from the 770 to the 780.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($229.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($31.99 @ Mwave)
Motherboard: Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard ($153.98 @ SuperBiiz)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory ($64.99 @ NCIX US)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Disk ($106.99 @ Best Buy)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($88.97 @ OutletPC)
Video Card: Zotac GeForce GTX 780 3GB AMP! Edition Video Card ($476.99 @ SuperBiiz)
Case: Corsair 300R ATX Mid Tower Case ($69.99 @ Micro Center)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($19.98 @ OutletPC)
Total: $1338.86
(Generated by PCPartPicker 2014-05-09 19:51 EDT-0400)
It comes out to about $1340.
I've also included a 128GB Samsung 840EVO PRO SSD.
Also, I've replaced your old HDD for the WD Black 1TB, which is better in the reliability and life-expectancy factor. (alot better than the Seagate.)
