Will this power supply be compatible with my CPU and Graphics Card?
glados
16
I actually have that same PSU with an i5-4670k and it works perfectly! As for the 2 7950's... the v850 will provide plenty of power and it has all the connectors you will need (2 8-pin and 2 6-pin) without having to use something like a molex to PCI-E adapter. I hope this helped! Here is a link to that same PSU at Newegg and it shows being 4th gen Intel compatible. http://www.newegg.com/Product/Product.aspx?Item=N82E16817171079
thanks for clearing that up for me, looks like ill be going with that psu. I also heard it is based off of a seasonic psu which is why it performs so well. thanks again.
it is made by seasonic and branded coolermaster.
