Will this power supply be enough to crossfire 6970s?
Slushyspy33
44
Hello I was wondering if I would be able to crossfire 2 sapphire radeon 6970s with this power supply.
http://www.sentey.com/en/xpp-725-watts-xpp725-ps
full specs(that matter):
i3 2120
3 120mm case fans
1 DVD-RW drive
1 TB seagate drive
1 60GB corsair Force SSD
I've heard many stories of crossfire with this power supply but I was just wondering because I know the 6970s are an older card and need more juice than the newer ones. It doesn't have all the cords but it comes with adapters.
It will work as long as the two 6+2 PCIE cables are enough.
That Sentey is actually based on a more budget level Super Flower Design. Good manufacturer but this is not a Leadex.
http://www.super-flower.com.tw/products_detail.php?class=2&sn=10&ID=57&lang=
Despite only being rated for 80+, it actually is a Silver unit under the lid.
http://www.hardwaresecrets.com/article/Sentey-SDP850-SS-Power-Supply-Review/1806/12
You know alot about sentey?
But it says on the page it has a very strong Rail...
See my edit above too.
Your PSU is good. As long as it's less than 5 years old and have the connectors, there isn't much reason to buy another.
If you do upgrade, the B2 that Blackbird showed you is a higher end SF design (Golden Green), just below Leadex.
Sentey is just the sticker on the box. You gotta see what's under the hood with these things.
Its brand new... I haven't Installed it yet.
Ok I just thought of something!
You know amd cards can crossfire if the GPUs have the same structure, so, what if I got a card similar the the 6970 but it consumed less power.
Please share your thoughts about if this is a good idea, and if so, what cards?
Power is not an issue here. I'm running a severely overclocked crossfire set-up on my SF 550W, lol.
