Will this power supply power my rig?
Roxas_Boy
1,211
I'm about to purchase a Silverstone ST50EF PSU which is pretty good, it has dual 12v rails each capable of providing 18 amps each.
My rig will have:
A10 6800K 4.4ghz
ASUS A85XM-A
LG DVD WRITER/READER
4 High Perf 120MM fans
8GBX1 DDR3 G.Skill Ram
ASUS R9 270
1 Samsung 840 Evo SSD
1 2TB WD Black HDD
Thanks for all the help but doesn't the rating at that website mean how many watts it'll take from the 12v rails (420w) and if it takes 410w of the 420w wouldn't it be cutting it close, if i'm incorrect I apologize it's just that I don't know much about this and I don't want to have wasted so much money because in my country (New Zealand) everything computer related is 180% the US cost
the 410w value assumes a 90% load on your entire system which is not going to happen outside of stress testing. basically such a value tells you what the absolute maximum your system is going to draw so then you can use a psu above that limit. during average use you will be nowhere close to this value however you need to plan for it.
your psu should be absolutely fine.
yes but if you dont plan for it and "do" hit the limit with stress testing... your whole system can shut down under load and thats not a good thing to let happen. that is why we plan for the theretical 100% maximum load (well the value i listed before was 90% but close enough considering the overhead the op has)
i've hit 420w on my older i7-920 system with a gtx470. it must be way less power efficient since its not even overclocked (it was during crysis.... perhaps that had something to do with it haha). luckily i have a huge psu (i managed to snag a 1000w corsair for the same price as the 750 awhile back)
@roxas
depends on the game.
if its a cpu heavy game then maybe. if its a gpu heavy game than not likely.
personally i dont think its a terrible matchup (though the FX lineup is likely a better choice since there isnt a need for an APU if you have a GPU already). run some tests and see what your cpu and gpu usages are in game.
I can't run the stress test at the moment, the only reason I'm buying a new power supply is because Christmas is coming up and I'm tired of this APU iGPU so I'll be treating myself with an ASUS R9 270 and needed to get a new power supply as my current one will probably not even boot with an R9 270
I need urgent help guys, I installed the new power supply I bought, did some intense cable managment (I have OCD) and now it looks and perfroms good. But my one major issue is that since I put this power supply in my OS hard drive is making a coil whine high pitched screeching noise for extended duration of time non-stop. I am worried and need any help I can get
