i'm not sure what power supply to get for the gtx 780 ti kingpin, i was reading online and on this website it said that this card requires a 2x 8-pin and 1x 6-pin pci connection. also is the wattage good for this card or should i get one with more wattage.
http://www.memoryexpress.com/Products/MX51750
i just wanted to ask if the corsair HX750 will be able to power the card.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139010&cm_re=crosair_hx750-_-17-139-010-_-Product
and if the power supply its not able to power the card, can someone recommend a good power supply unit.
thank you
thank you
